I'm thinking it's the map.
Garret Gt3076R on standard manifold 63AR I think
Wossner
800cc sard
Link G4
Phoenix Power intercooler
![Image](http://i209.photobucket.com/albums/bb305/Odin_S/20150509_103133_zps73cjiqhx.jpg)
![Image](http://i209.photobucket.com/albums/bb305/Odin_S/20150509_103142_zpsscbnd1yg.jpg)
![Image](http://i209.photobucket.com/albums/bb305/Odin_S/20150509_103148_zpssk81kbnt.jpg)
ashley wrote:I reckon you might need to advance your inlet cam by 1 tooth, I would defo be checking the cambelt is timed up correctly- that double dip don't look right.I thought it might be the boost backing off too much once the waste gate opens, but looking at your boost plots it doesn't dip that far
As Jim says- I'd be checking the basics first- static ignition timing is a good call as well..
.then back to the dyno.
Out of curiosity- was this on fresh 99ron fuel??
EGT= exhaust gas temperature, it's a good indication of back pressure- you mentioned you're on the smallest GT30 housing, so you might find EGTs are pretty high.
.but I'd expect you to be alright up to 1.5bar unless something else is happening.
What exhaust do you have
(what bore is it all the way through)?
kev8611 wrote:This is very similar to mine except i made 330 but only 260 odd at the wheels.
I have the same dip in my graph too.
