[Mk2] [Turbo] Exhaust blow from manifold to turbo
philmr2
Post by philmr2 »
As above,I don't know if I'm missing something on this one as I have now tightend one nut in particular 3 times out of the four nuts to eliminate the blowing, but after driving for a mile or so the dam thing comes loose again.
Does anyone have any ideas as to what could be going on with it, both the nuts and threads are okay and they have been tightened well.
Cheers Phil
mr2magic
Re: [Mk2] [Turbo] Exhaust blow from manifold to turbo
Post by mr2magic »
Exhaust manifold nuts tend to be one time use as they have a simple locking function - either the rear of the nut is slightly oval or the nut has a groove cut into the rear which compresses during tightening.
Just buy new ones and tighten once.
philmr2
Post by philmr2 »
Thanks for the reply I will get some on order, I assume they are readily available from Toyota.
kev8611
Post by kev8611 »
Yeah they are generic on most toyotas. I got a handful there and then from my dealership
gnzyza
Post by gnzyza »
I believe the turbo to manifold are locking type nuts and about £4 each from the dealers
asdrewq
Post by asdrewq »
gnzyza wrote:I believe the turbo to manifold are locking type nuts and about £4 each from the dealers
:o Ouch!
mr2magic
Post by mr2magic »
Just get generic ones...don't have to be oem ;-)
gnzyza
Post by gnzyza »
philmr2
Post by philmr2 »
Got some coming from a motorcycle suppliers pack of ten for £8.00 :thumleft:
