ok guys,
am replacing my front brakes this weekend (leaky caliper seals) but one problem, it currently doesn't have any shims between pads and pistons.
So I have bought them, but don't know which way they go on, serrated one nearest pad or piston?
Thanks people
Andy
brake pad shims
Re: brake pad shims
According the the bgb the serrated one is sandwiched between the back of the pad and the larger flat shim. I recommend lightly coating each side of the serrated shim with anti seize paste (copper grease)
Re: brake pad shims
Thanks buddy, appreciated and will do.
