had them on current and previous car set somewhere in the middle, never really altered them so just wondered what other people have them set at.
Mainly for road use but interesting to see what people alter for track use too
For those with Koni Adjustables - what setting do you use?
Re: For those with Koni Adjustables - what setting do you use?
I would set em to full hard .... see what that's like
Then to full soft .... ditto
Then progressively adjust to intermediate settings
Peter
1989 MR2 Mk1 NA T-bar
1998 Ssangyong Korando GLS
2011 Honda Civic Type R
I always found full hard to much for our roads. The ride was crashy and the rear would lift to much on bumps. I use to run them half way, kept the car flat while remaining comfortable.
- Lauren
- IMOC Committee
About halfway on front and rear. Stiffen up the rear to full stiff for track use.
2020 GR Yaris - Circuit Pack
+1 with Lauren.
Hard is far too uncomfortable for our roads.
However I did try it before my belt snapped along with the MK2 ARB and it was awesome! My back felt awful though!
Can you still buy new koni' s ?
Mk1b White T-bar SC 1987, Mk1b White coupe Jan90, Mk1b White coupe Jan90 (spares), Mk1b Mica blue T-bar Mar90, Mk1b Mica blue T-bar,full climate control,Jan90, 5 mk1's
A quick search seems to suggest that the dampers are still available individually but the SSK appears to be no longer listed anywhere that I could see.
Larkspeed are still selling them. £115 each
Thanks for the replies
Tried playing around with the settings but ended up back around half way as suggested
