[Mk2] [NA] Turbo gearbox mate up to non turbo.
Will a turbo gearbox with lsd work as a direct replacement onto a UK non turbo lump?
Re: [Mk2] [NA] Turbo gearbox mate up to non turbo.
BALDYMONSTER wrote:Will a turbo gearbox with lsd work as a direct replacement onto a UK non turbo lump?
It will if you change the clutch plate, mounting, driveshafts etc.
Not sure why you'd want to though...
Fitting nitrous kit.
BALDYMONSTER wrote:Fitting nitrous kit.
N/A gearbox will be fine. Fit an LSD if you want.
Where can I get an lsd?
I'm running gas on mine on a stock gearbox. Why are you going for a tubby box?
BALDYMONSTER wrote:Where can I get an lsd?
From Quaife, a UK Roadster or some late JDM N/As.
