pictures of standard dash at night pls.
gerbil1028
Post by gerbil1028 »
Hi all thinking of removing my el-glow speedhut dials and going back to standard.
Not sure how visable the standard dash is at night so a request for standard dash at night pics only please.
Not got time at moment to do the fancy plastic sheeting and leds at moment and I know that looks good, but after standard only for now.
Cheers ian
One day the Phoenix will rise from the ashes.
Peter Gidden
Re: pictures of standard dash at night pls.
Post by Peter Gidden »
Camera will not show what the dash looks like in real life.
Stock dash illumination is perfectly fine. Not bright, not multi-coloured, not like an 80s disco light show. But guess what - it allows you to read the instruments at night.
C35Rob
Post by C35Rob »
Peter Gidden - SBITS wrote:Camera will not show what the dash looks like in real life.
this..
you don't want the dash to be super bright and full of LED's.. at night the softer the lighting is inside the car the better, allows you to see more of the road and not be dazzled/distracted
https://www.youtube.com/watch?v=Xgh2zbifn7E this is where it's at.. minimal intrusion.
gerbil1028
Hence removing el-glow as even on lowest setting its ridiculous
Nails
Post by Nails »
I binned my elgow stuff for the same reason. Looks a bit chav too.
this..
Agreed. LED bulbs replacing the stock bulbs all over the dash sucks. Stock lighting is the way to go. Nice and easy on the eye.
gerbil1028
Agree with the el-glow but as I was a boy racer MacDonald car parker last time I owned the car and fitted them it was well cool and added 100hp
slipping clutch
Post by slipping clutch »
gerbil1028 wrote:Agree with the el-glow but as I was a boy racer MacDonald car parker last time I owned the car and fitted them it was well cool and added 100hp
Only 100 H.P. ? you bought the cheap ones then!
I have a decent set of 'el glow' dials from speedhut with the adjustable invertor and I really like them, not to bright at all and not chavvy either in my opinion However as I haven't driven the car at night for 4 years now I might change my liking of them!
JohnnyC
Post by JohnnyC »
I quite liked my elglow dials :)
And standard (rev5)
Pauln
Post by Pauln »
JohnnyC wrote:I quite liked my elglow dials :)
+1 I've just upgraded my turbo speedo cluster to the same Speedhut dials as yours, and am well pleased with the result.
I don't know if they were stock JDM or were fitted on import, but the original black dials on my 92 JDM rev 2 n/a were truly awful and very difficult to read at night. The illumination was far less even than that of your stock dials, which was why I changed them to Lockwood dials. These were much more even at night, but unfortunately not very clever around dusk.
To be fair Speedhut dials are a bit more subtle than the dials usually referred to as elglow, like these Shinny had for sale
forum link
Which are more of an acquired taste.
Paul
Nic
Post by Nic »
I used EL glow panels and coloured gel film to back light my stainless steel dials, they were the same as the ones in the link below but I asked the seller for un-printed ones. They could be used behind standard gauges and would give a much more even light spread through the dials. The odometer and needles are lit with white leds in place of the standard bulbs.
http://www.ebay.co.uk/itm/LETRONIX-Plas ... 58bade425e
Nic
[email protected]
MR2 Rev 3 GT Turbo
gerbil1028
Mine has not black on my speedhut ones. The entire faces light up and glow. Picture in build thread.
These are ridiculous and just too much so I am now running standard dials with many blown bulbs doh!!
Anybody know the fitment size of the standard bulbs so I can get some replacements
JohnnyC
Post by JohnnyC »
gerbil1028 wrote:Anybody know the fitment size of the standard bulbs so I can get some replacements
A search reveals them to be 501 size.
I put 501s in mine, and they were way too bright - but luckily I had a UK car with a dimmer control.
So I think you'd be best off getting 504 bulbs (identical, but only 3W as opposed to 5W of 501s).
gerbil1028
Cheers :thumleft:
Assume pull out push in type of bulb holder then
JohnnyC
Post by JohnnyC »
Yep, just twist the large plastic bulb holders...
Gullzter
Post by Gullzter »
This isnt standard but just a set of leds:
Looked really good on eye although the picture picked up quite alot it wasnt as bright to the naked eye.
Just thought id throw that in there for you to make your mind up :thumleft:
SonicSW20
Post by SonicSW20 »
Stock Rev4. Wheel obviously not stock. Exposure has brightened them up a bit.
outrun
Post by outrun »
Binned the daft, silver dial faces and blue LED's that came with mine, in favour of stock dials and bulbs.
They are perfectly adequate and look miles better, imo.
Harrodbear86
Post by Harrodbear86 »
Looks cool
