Here are some photos comparing a Rev 2 Turbo Block and a Rev3 NA Block
I'm trying to figure out the best combination of Inlet manifold support bars for a gen 2 engine running a gen 3 Turbo head.
You can see the threaded holes on the Gen 3 NA block are unfortunately different to the Gen 2 Turbo block
Can anybody with a Gen 3 TURBO engine block post a photo of the inlet manifold side?
I want to check if the turbo Gen 3 block is exactly the same as the Gen 3 NA block
Also anybody else who's fitted a Gen 3 head - did you find a good way to make the inlet mani supports work?
Thanks!
Dan
Gen 2 Turbo Block
Gen 3 NA Block
[Mk2] [Generic] Rev 2 / Rev 3 Block Comparison - Pics inside - need Rev 3 Turbo Block Pic!
Re: [Mk2] [Generic] Rev 2 / Rev 3 Block Comparison - Pics inside - need Rev 3 Turbo Block Pic!
Somebody who's built a Rev 3 engine must have taken a snap shot of the block on an engine stand??
Unfortunately google images keeps showing me the turbo side
Bump, anybody got a photo of a rev 3 block turbo side?
Bump up - Can anybody show a photo of a Rev 3 turbo block, Inlet side?
I don't have a pic, but I did fit a rev 3 head onto a rev 2 block once, and I just didn't bother with any inlet manifold supports.
Don't know if that helps at all, but seeing as no-one has answered you since January... it might be better than nothing
January 2014
May 2015
Still in the garage...
..the only thing I can promise for sure is slow progress.
May 2015
just have this niggling thought that if I rip out the wiring, then the car will never get out of the garage again.
My old Rev 3 turbo block inlet side on the stand.
I'm having the same issue at the moment, trying to re-assemble a rev 3 turbo engine and figured out where the two long supports go but I've got two short ones left and no idea how they fit?!
CalMac wrote:I'm having the same issue at the moment, trying to re-assemble a rev 3 turbo engine and figured out where the two long supports go but I've got two short ones left and no idea how they fit?!
There are lot's of braces around the 3SGTE. On the Rev 2 there is a short one from block to driveshaft support bearing, short one to the alternator bracket I think and a short one up to the engine mount on the transmission side
