Hello folks, haven't been about in a while. Hope you're all well.
I've a rattle that sounds like it's coming from the top of the engine, from under the cam cover. It's most noticeable around 2000rpm. Is this a likely cause? Or should this move as freely as this?
Checked the clearances wiggle the cam cover is off, all fine.
Thanks in advance
