[Mk2] [Turbo] Fitting TRD rear brace with Greddy IC Pipes
User avatar
Scott Barton
Post by Scott Barton »
Ok...I have a slight problem.
I got my hands on a brand new TRD rear brace but have run into an issue with fitting it. The issue is that it won't clear the intercooler pipes in the engine and no matter how much i try and angle the pipes, adjust the hoses etc, it still sits on top! I can't leave it like it as it will ruin the pipe and/or the brace.
Am thinking of cutting pipes down so that they sit further down...anyone else had the same issue with a TRD brace?? Any pointers?
rev2rich
Re: [Mk2] [Turbo] Fitting TRD rear brace with Greddy IC Pipes
Post by rev2rich »
I run mine with a Radtek cc had no real issues
ashley
Post by ashley »
Stick a few pictures up Scott- lets have a look...
JAAASH
Post by JAAASH »
I had this issue with mine too. Sold the brace in the end so never sorted it.
Berk cold pipes are supposed to clear TRD braces, although I have no personal experience.
http://www.gtschris.com/store/comersus_ ... Product=66
_________________
"What the Deuce?!"
My MR2 - http://www.imoc.co.uk/forums/viewtopic.php?t=174494
User avatar
Scott Barton
JAAASH wrote:I had this issue with mine too. Sold the brace in the end so never sorted it.
:thumleft: Good spot!
Rob
Post by Rob »
Can you use those little spacer blocks on the turrets that some MR2's have from new?
User avatar
Scott Barton
Rob wrote:Can you use those little spacer blocks on the turrets that some MR2's have from new?
Thats not a bad shout either! Every mm will count!
These bad boys!
http://www.ebay.co.uk/itm/Toyota-MR2-MK ... 1459754315
Rob
Post by Rob »
Yep!
User avatar
Scott Barton
I bought those ones, and the Berk pipe arrived the same day. Just need to put it all together now. :thumleft:
Quigonjay
Post by Quigonjay »
JAAASH wrote:Berk cold pipes are supposed to clear TRD braces, although I have no personal experience.
they do indeed clear
I have the trd brace and this pipe
User avatar
Scott Barton
Good stuff. I bought one from GTSChris. Having an 'MR2 day' this week to do some jobs and this is top of the list. :thumleft:
