Hi Gents,
I'm looking to update the rather rubbish boost gague thats in my rev 3, but im desperate to only go for an OEM+ look, so no horrible pods or runnish stuck on things anywhere.
Where I'm stuck is......
Is the standard mechanical or Electronic?
What can people recommend?
Pictures on a postcard
OEM Style Boost Gagues
- IMOC Moderator
Re: OEM Style Boost Gagues
Stock one is electrical, go to r-spec.co.uk and buy one of their 45mm gauges, once you take the lens of it it's perfect fit into the OEM slot, looks muuuuch better than omori etc, it actually looks totally OEM, the only thing is it lights up amber and that's the only option available
available in Bar or PSI
http://rspec.co.uk/performance-gauges/4 ... tor-series
Yeah 45mm and some time and effort's and its a good'n ...
Perfect!!
So is it easy to change over? Any drilling, wiring or whatnot needed?
Just face off and plug in?
- IMOC Moderator
androo007 wrote:Perfect!!
You'll need to extend the wires for the boost gauge which is obviously a piece of p1$$. Taking the lens off the gauge is easy, just a tiny screwdriver and pry around the edges, you'll see what i mean once you have it. There is a small issue with the wee light tunnels for the indicators, you kinda need to break these a wee bit (to get the new gauge to fit) so your indicator dash light now shows as green. these wee tunnels keep the light from other areas out so your indicator dash light appears as black, with these broken the light gets into them. I coloured mine in with black marker
Grill, thanks man much appreciated. Wonder if the unit comes apart to change the filter from amber to white....
- IMOC Moderator
androo007 wrote:Grill, thanks man much appreciated. Wonder if the unit comes apart to change the filter from amber to white....
unfortunately not, it's not a filter, the LED is amber and by the looks of it (i had a broken one to take apart) you'd need to solder a new one in which is near impossible as the needle does not come off regardless how hard you try, you will end up breaking it
EDIT: it's also tiny!! i could hardly find it!
Ahhh never mind. Still love the look and it's gotta be better than the laggy rubbish stock one! It doesn't even move until I'm in + pressure!
- IMOC Moderator
androo007 wrote:Ahhh never mind. Still love the look and it's gotta be better than the laggy rubbish stock one! It doesn't even move until I'm in + pressure!
yeah the stock one is garbage mate, your only real option would be to make the rest of your dials amber, the gauge sticks out like a sore thumb, you could try adding a wee filter but i tried it with some blue and it hardly lit up at all there's plenty space for a wee filter, the blue i used was pretty dark too.
Another option, is what I have fitted to mine, EMS red digital boost gauge:
Ah that's nice man, but I wanna try and stay OEM looking if I can. Thanks for the suggestion though! Looks ace
androo007 wrote:Ah that's nice man, but I wanna try and stay OEM looking if I can. Thanks for the suggestion though! Looks ace
No prob dude
sheppy wrote:androo007 wrote:Ahhh never mind. Still love the look and it's gotta be better than the laggy rubbish stock one! It doesn't even move until I'm in + pressure!
Think I might get myself an early Xmas present! Thanks for the advice dude
- IMOC Moderator
No probs man. Just be gentle when removing the lens. It's a sturdy wee unit but the needle etc is exposed once you get the lens off
RedMR² wrote:Another option, is what I have fitted to mine, EMS red digital boost gauge:
That looks super , Craig
ive got an old white backing to the dials if you want it to play with
Absolutely nothing wrong with the omori gauge and my indicator lights still work perfectly.
- IMOC Moderator
tubby_tony wrote:Absolutely nothing wrong with the omori gauge and my indicator lights still work perfectly.
it doesn't look anywhere near as OEM as the prosport gauge IMO. Doesn't look bad of course, just not as nice or as OEM looking as the prosport guage, also, easier to get hold of and cheaper than the omori
2mad wrote:RedMR² wrote:Another option, is what I have fitted to mine, EMS red digital boost gauge:
Image Replaced With URL For Quote http://twosrus.com/catalog/images/mr2_c ... auge_8.jpg
Yeah, does look pretty good. Also available in blue.
I replaced the circuit board that drives the stock boost gauge with my own board with an AVR. The boost gauge is much more responsive now and it's now calibrated exactly how I want it to be. It's driven from the same MAP sensor signal the ECU uses for fuelling so it's give a good indication of what boost the ECU is actually seeing
I was planning on making the software and hardware open source if anyone is interested?
