[Mk2] [NA] 3SGE MR2 G Limited 1993 engine problem solved at last
Hi guys I dont know what I did but I adjusted the tps sensor and adjusted the throttle cable and sprayed the breather pipe between rocker cover and throttle body with carb and air take cleaner and sprayed it into the connectors in the rocker cover and throttle and its cured the mis fire and cutting out i noticed white gunk in the oil cap and that breather pipe which got cleaned out and the car is working fine. The breather pipe has got a crack in it but I have taped it up until i get a new one so i am assuming condensation got in through that and clogged up the breather that prevent car starting etc.
