i think i fried my car... im such a dumb ass help pls
QUOC2008
Post by QUOC2008 »
I think i fried my car...by jump starting the car the - & + wrong way around in the dark and turn the key. Now the dash and car doesnt start... :$
Rev5GT
Re: i think i fried my car... im such a dumb ass help pls
Post by Rev5GT »
I think there's a fuse / relay that will have popped..
Peter Gidden
Post by Peter Gidden »
Could be the fuseable link in the main =VE battery lead.
Battery is always -VE to passenger side, whether light or dark. Doesn't change when the lights go out.
QUOC2008
Post by QUOC2008 »
Hopefully it hasnt damaged anything thanks... i will try changes thhe fuses relays etc
Peter Gidden
No point in checking any relays. They have nothing whatsoever to do with circuit protection.
Start with checking for 12V+VE at ALT fuse or AM2 fuse. If no volts you've blown the fuseable link.
If you have continuity then check other fuses.
QUOC2008
Post by QUOC2008 »
Peter Gidden - SBITS wrote:No point in checking any relays. They have nothing whatsoever to do with circuit protection.
Thanks will do
QUOC2008
Post by QUOC2008 »
It seems to be alot worse my car isnt a normal dash it has the dash2pro and a custom ecu with custom wiring... all gonna come out now
thomp1983
Post by thomp1983 »
Have you done the checks Peter said? A custom dash and standalone ecu shouldn't remove the fuseable link which is installed near the battery terminals
QUOC2008
Post by QUOC2008 »
Yes im afraid its alot worse im.gonna have replace everything to garrantee no fire issue loom... etc i was lucky the battery didnt blow up
QUOC2008
Post by QUOC2008 »
Pain... its gonna cost me silly money
2mad
Post by 2mad »
QUOC2008 wrote:Pain... its gonna cost me silly money
Damn what a mistake ... feal really bad for you :cry: .. hope you sort it mate.
QUOC2008
Post by QUOC2008 »
Thanks... but i know its gonna cost serious money now i never have good luck with these cars this is my 4th one...
2mad
Post by 2mad »
Petes right .. need to hit the fuse's .. like I said .. hope you sort it mate .
SySanguinary
Post by SySanguinary »
I'm not clear whether you've checked the fusable link yet. Have you stripped the cable tape back before the +ve terminal on the main loom yet and inspected the link there?
SySanguinary wrote:I'm not clear whether you've checked the fusable link yet. Have you stripped the cable tape back before the +ve terminal on the main loom yet and inspected the link there?
^This. Wasn't sure whether the fuse-able link had been checked either.
QUOC2008
Post by QUOC2008 »
Im not sure but some of the things have melted... rip open the ecu, wires, dash... i dont know...
SySanguinary
Sorry, I give up. You're not really making much sense!
Peter Gidden
QUOC2008 wrote:Yes im afraid its alot worse im.gonna have replace everything to garrantee no fire issue loom... etc i was lucky the battery didnt blow up
What are you talking about?
Have you read the reply i bothered typing to try and assist you?
If you have, did you bother following my instructions?
FYI, here it is again:
If you want members to offer you help then stop posting random gibberish and use the assistance offered. :roll:
QUOC2008
Post by QUOC2008 »
Yes we have check the fuses
Peter Gidden
QUOC2008 wrote:Yes we have check the fuses
Go on then.........
And???
