QUOC2008 wrote:No i did not..
oh is that a problem maybe its the d2 kit
Adam86 wrote:You can also make an adjustment to the rod that goes from the pedal to the master cylinder.![]()
After changing my front pads my pedal went soft when pumping the right front after the pad change.I could however pump the pedal up on the second push.
I had to adjust the rod and they are sharp again now but you have to be careful or you will get permanent brake drag.
