I have a tubby gearbox but it had the non abs shafts, can I just put abs shafts in it or do I need to have the inner cv joints to the box and fit those to a set of abs driveshafts?
Any advice would be great! It's going into my rev3na converted v6
[Mk2] [Generic] E153 lsd tubby box, non abs shafts...can you put abs ones straight in?
Re: [Mk2] [Generic] E153 lsd tubby box, non abs shafts...can you put abs ones straight in?
mk2mattw wrote:I have a tubby gearbox but it had the non abs shafts, can I just put abs shafts in it or do I need to have the inner cv joints to the box and fit those to a set of abs driveshafts?
As long as the shafts are turbo LSD abs they will fit
