As he describes the problem to me:
In 1st, 2nd and sometimes 3rd gear when boosting above 14psi the car will jerk between 3000-4000rpm and then will continue to boost fine.
He recently installed an ebc in the car
He has unplugged the tsvs but the vac pipes are not blanked off.
He has replaced his ignition leads but the problem is still there.
Any ideas would be much appreciated and I can get more info on the issue if needed
cheers
Ross
