Gareth's 1999 Sonic Shadow Revision 5
SonicSW20
Re: Gareth's 1999 Sonic Shadow Revision 5
Post by SonicSW20 »
Finally got round to doing the front, but of course there's a problem. Here are my nice freshly passivated and coated front tension rods. A pair of right hand side ones! :lol:
Good thing there's a left on on the car eh!
JD
Post by JD »
Spectacular! Always nice to have a spare.
SonicSW20
Post by SonicSW20 »
Went up to the Dales for a week in October. Only managed to break it a little bit once! Nothing serious, just spent more time than I would like with all 4 wheels not touching the tarmac, or anything at all for that matter... The worst damage was to my spine for a few days, and a dislodged exhaust clamp. Won't be doing that again any time soon!
The particularly hawk eyed among you may notice that it has new tyres - Advan AD08R's. Just in time for winter! 8-[
Annoyingly the place that fitted them a few days before leaving for Yorkshire did a xxxx job on the balancing, and I only found out on the way to Yorkshire. Loathed to take it back to them tbh, but it needs to be sorted.
Next big day out - Snetterton in a couple weeks, with 2x 2GRFE swapped SW20's, another 3x SW20 Turbo, and a 1MZ Supercharged AW11 MR2. Should be fun!
2barGee
Post by 2barGee »
Are you running more camber at the rear than the front or is it just the pictures that make it look like that?
I must do Snetterton next year!! One of the only tracks I've not done, mainly due to the distance it is from mine!!!
SonicSW20
Post by SonicSW20 »
2barGee wrote:Are you running more camber at the rear than the front or is it just the pictures that make it look like that?
There is at the moment by about 0.5 degrees, need to get some camber bolts for the rear, as it's a PITA to set the rear accurately without them.
2barGee
Post by 2barGee »
Guess it depends on what they are currently set at? Or run more at the front and leave the rears?
I'm running -2.0 at the front and -1.5 at the rear and its been very stable in the bends.
SonicSW20
Post by SonicSW20 »
Its set as negative as it will go at the rear, front is set precisely as it has the camber adjustable top mounts.
It's about -2.0 front and -2.5 rear. I want ~ -2.0 all round ideally.
On the previous setup I had for a very brief period -2 degrees front, and about -0.5 degrees rear. Turn in was very sharp but the rear really lacked grip compared to the front mid corner, and really was not too enjoyable. Was my fault, I'd swapped the subframes and only set toe after, didn't think about camber!
rossonza
Premium Member
Post by rossonza »
frustrating on the arms hahaha. love the pics! :thumleft:
SonicSW20
Post by SonicSW20 »
Snetterton didn't go too well for me unfortunately!
Clutch issues.
2barGee
Post by 2barGee »
Gazza_DJ wrote:Snetterton didn't go too well for me unfortunately!
Image Replaced With URL For Quote https://i.imgur.com/4Ofaox7.jpg
Clutch issues.
what went wrong mate?
SonicSW20
Post by SonicSW20 »
Hyrdaulic issue which has probably caused a mechanical issue as well. Sounds like a spring has failed on the pressure plate, but we won't know until it's all off.
2barGee
Post by 2barGee »
Gazza_DJ wrote:Hyrdaulic issue which has probably caused a mechanical issue as well. Sounds like a spring has failed on the pressure plate, but we won't know until it's all off.
Did you manage to get any laps in before the issue occurred?
SonicSW20
Post by SonicSW20 »
3 sighting laps and 3 laps in the morning, rest of the day spent changing components and bleeding the damn thing to no avail.
SonicSW20
Post by SonicSW20 »
Looked good for the few laps it was out for:
SonicSW20
Post by SonicSW20 »
Mechanical failure confirmed:
Took apart the master, seals were worn out on that as well.
Ryan S
Post by Ryan S »
i had this happen on a split new exedy clutch mate. I don't use exedy anymore.
SonicSW20
Post by SonicSW20 »
Ryan S wrote:i had this happen on a split new exedy clutch mate. I don't use exedy anymore.
Standard / OE replacement or an upgrade one?
Ryan S
Post by Ryan S »
The friction plate was identical to the one in your pic, so whatever that was. I actually had the same problem on a 200sx too, well it was similar i guess, that part that retains the spring completely sheared. Again that was an exedy.
2barGee
Post by 2barGee »
How do you find AD08r in the rain?
what clutch will you be getting now?
SonicSW20
Post by SonicSW20 »
Competition Stage 2 is in, just need to pick it up.
AD08R's are much better than you think in the rain, about in line with your average mid range tyre. Not as good as something like a Michelin Pilot Sport 4 for example, but that's the tradeoff.
I'd have no issue using AD08R's (with good tread) all year round in the southern/mild parts of the UK.
