[Mk2] [Turbo] Turbo Engine Block
Quibble
Post by Quibble »
I've got a running daily driver rev 3 turbo that I am thinking about forging but would like to keep it on the road up until the last minute, so was thinking about getting someone to build me a short block while I keep the car on the road. I still have the engine from my first mr2, a rev2 turbo sitting in the garage. Is the rev2 block compatible with the rev3 engine? Thanks
bobhatton
Re: [Mk2] [Turbo] Turbo Engine Block
Post by bobhatton »
Quibble wrote:I've got a running daily driver rev 3 turbo that I am thinking about forging but would like to keep it on the road up until the last minute, so was thinking about getting someone to build me a short block while I keep the car on the road. I still have the engine from my first mr2, a rev2 turbo sitting in the garage. Is the rev2 block compatible with the rev3 engine? Thanks
Up to a point yes.
The Rev2 block needs work to fit the Rev3 sump, that is about all that needs to be done.
Quibble
Post by Quibble »
Is there any advantage to using the rev2 block, if not then I have my answer, I need another rev3 block?
bobhatton
Post by bobhatton »
Quibble wrote:Is there any advantage to using the rev2 block, if not then I have my answer, I need another rev3 block?
Rev 3 blocks can crack, rev 1&2 I understand are stronger and do not crack.
GeorgeL
Post by GeorgeL »
They all can crack.. I've seen examples of them all. The whole "rev 1/2 is stronger" is nonsense
'98 Rev5 Turbo (GEO 1S)
TOTB13 RWD 1/4mile 1st place
TOTB14 RWD 1/4mile 3rd place (Misfiring)
TOTB15 RWD 1/4mile 2nd place (HG Failure)
TOTB16 RWD 1/4mile 1st place
bobhatton
Post by bobhatton »
GeorgeL wrote: The whole "rev 1/2 is stronger" is nonsense
I think the same way, but to date I have only seen 2 Rev 3 blocks crack.
simpson_eh
Post by simpson_eh »
got a rev 3 block and crank for sale if needed, no rods or pistons and needs a slight bore which is fine if replacing with 86.5
didnt even notice till it was stripped, only took it out to drop a 5s in
