![Image](http://i.imgur.com/LXCPOX5.jpg)
I've been using the stock flat seated nuts with these wheesls
Are these wheels designed for flat seated nuts, or should I be using a tapered nut?
Gazza_DJ wrote:
So is that definitely a tapered fitment in the picture? I suppose I'll need to measure the taper angle?
Gazza_DJ wrote:I've just ordered some from DriftWorks as they looked like they might be finished to a higher standard and they weren't that much more.May as well give it a go!
JD wrote:another vote for tapered- looking at the lip in the photo
Although it looks quite shallow so flat OE type would, in this case, probably also be fine.
