At the time I was working for toyota as a technician where I had been for 6 years
I always said if an mr2 turbo was to be traded in i would buy it.
Well as luck would have it I got wind of one being traded in for just
So I said I would have it without seeing it.
When it turnt up the red paint was pink the osr light was cracked and it had some awful fox racing 15" non staggered alloys but no rust atall and was almost completley original except for pivot oil pressure and boost gauge and an hks urbo timer.
so I got it home and in the garage and started to clean it up
And then it looked like this
I then turnt my attention to the
Aswel as new plugs leads fuel filter dizzy cap and rotor arm.
Along with some mods including an ebay side mount with custom made pipeing as the cold pipes are crap.
I then got some coilovers from turbo tom
She currentley looks like this
and a finished shot of the engine bay
oh and new seats have just been fitted
Current spec
Spec list
Toyo sports downpipe decat
Hks filter
Hks intake pipe
Hks adjustable BOV
Jp performance side mount
Spal fan and surround
Forge actuator
Manual boost controller
Ngk ik22 plugs
Stef derner delimiter
Powder coated engine parts
Allen key bolts
Sbits gear shift bearing bushes
charcoal canister delete
aircon delete
Coolant to throttle body line looped
New rocker cover gasket
Bosch leads
New dizzy cap and arm
New king lead
New coil
Custom lid fan
Blueflame exhaust
Suspension
F+R arb polybushes
Tein coilovers super streets
Tein adjustable top mounts
Cusco adjustable tension rods
20mm rear spacers
5mm front hub centric spacers
Camber bolts all round
17x9
245/35/17 and 215/40/17
Falken 452s
Purple d1 spec nuts
Exterior
Import plate holder
Clear indicators
Black rear center panel
Gloss black spoiler
Rear grill removed
Yellow tinted front fogs
clear headlights
osram nightbreaker bulbs
Interior
Fire extinguisher
Genuine retrimmed nardi wheel
Trs takata green harness
B+G steering spacer
D1 spec weighted adjustable gearknob
New leather gear gaitor
Recaro speeds
Alpine headuint
Hks turbo timer
Pivot stepper gauges in a pillar pod
Rrtrimmed inside glovebox with light
man in dandisim mats
Brakes
Hell braided brake hoses
carbotec front and rear pads
Red brake calipers
quater of a mile in 13.08
