Would you believe i've never needed a puller on any Toyota crank pulley in 15 years?
Equal pry bar pressure at both sides, and i do mean equal, and they come off quite easily, the second you apply even a few more lbs.ft to one side than the other and the pulley jams on the crank, a smooth equal draw does the trick.
The worst case i ever had was a rusted on one that needed some light heat, after that the equal draw method worked as before.
Literally hundreds of pulleys removed this way, it's user error, you're doing it wrong, especially when the pulley has not long since been fitted.
