I have a miss matched set of enkei alloys.
Fronts are solid and the rears are splits.
good stagger, gives a mean stance when fitted.
Fronts 16 x 7 ET 35
Rears 17 x 9 ET 22
One rear has a bit of curb damage.
Very light wheels.
Oh yeah, pcd is for mr2 114.3 I think...
£250
Enkei alloys
Enkei alloys
Re: Enkei alloys
Diameter?
Widths?
PCD?
Offset?
Center bore?
Stright/true?
Any damage?
Might help your ad.
Widths?
PCD?
Offset?
Center bore?
Stright/true?
Any damage?
Might help your ad.
Re: Enkei alloys
Are these in Kent?
Would you consider a swap/trade for some 16" Sparco wheels in need of a refurb but in good condition?
Re: Enkei alloys
yes they are in kent, apologies though I cannot take any swaps or part ex's, I'm trying to sell stuff to free up space you see.
Re: Enkei alloys
Ok thanks, let me know if you change your mind
They are quite rare Sparcos so i'm told
Re: Enkei alloys
bump!
Re: Enkei alloys
Hi mate, would you be willing to post these?
Re: Enkei alloys
i may consider parting due to the lack of interest in the lot.
the reason i wanted to get rid of everything is so i'm not left with hundreds of bits taking up all my space, that and it takes alot of time and effort which i just don't have.
Just thought i'd add, the engine in the frontal damaged car had only done less than 4k since it had the head refaced, new head gasket, water pump, belt and idler. It was running v nicely.
Re: Enkei alloys
I thought this post was just for the enkei's?
Re: Enkei alloys
sorry, i dunno how that ended up here, should've been on the job lott thread.
i would post the wheels yes.
Re: Enkei alloys
So so cool....
I want those rears.... Agreed on aggressive stance on that offset... Oooooossshhhh
The most important question is
Are the rears welded splits?
(Peel away at any sealant and see if there's welding apparent)
Let me know
Let me know
Re: Enkei alloys
i'll have a look tomorrow afternoon and let you know sir.
Re: Enkei alloys
CardHore wrote:So so cool....
Let me know
That's why raptor jesus invented the angle grinder
Re: Enkei alloys
Just scraped all round the inside of the mating edge between the inboard barrel and the back of the hub part and there doesn't appear to be any weld, so i assume they are shrunk on or pressed into place.
Re: Enkei alloys
Try the well where the tyre sits, thats what I meant dude. You should see a bead of sealant... Pry some of it away and see if you can see any welding bead. You cannot tell from inside the wheel
Re: Enkei alloys
How much posted for just the pair of 16 x 7 ET 35 Enkeis?
Defo 5x114.3 Mr2 fitment? What's the center bore on the back of the wheel?
Thanks.
Thanks.
Re: Enkei alloys
Hi do you still have theses for sale
Re: Enkei alloys
CardHore wrote:Try the well where the tyre sits, thats what I meant dude. You should see a bead of sealant... Pry some of it away and see if you can see any welding bead. You cannot tell from inside the wheel
the barrel is just one big single piece, looks machined, no sealant or welding going on there. i'll take a picture.
Re: Enkei alloys
RedMR² wrote:How much posted for just the pair of 16 x 7 ET 35 Enkeis?
Thanks.
£175 posted
definately mr2 fitment, had them on mine.
c/b 65mm on rears.
