Hey folks looking for some advice. Got a phone call from the machine shop to say my crankshaft is beyond economical repair. So on search of looking for a new crank I came across the 2.2 stroker kits. Does anyone have any experience with these? Would I have to fit new cams and get a standalone ecu to make the most of it?
Any advice would be greatly appreciated. Meant to say the car is a rev4 turbo.
Rebuild options
Re: Rebuild options
davew90 wrote:Hey folks looking for some advice. Got a phone call from the machine shop to say my crankshaft is beyond economical repair. So on search of looking for a new crank I came across the 2.2 stroker kits. Does anyone have any experience with these? Would I have to fit new cams and get a standalone ecu to make the most of it?
What 2.2 stroker kits?
Re: Rebuild options
You can fit a 5S crank shaft into a 3S block, but you'll need to modify the crank for the 3S rods to fit (the big end journals need turning down).
I think you can also buy stroker cranks that are a direct fit, isn't that one of the cranks that you've used in your build Bob (can't remember the manufacturer)?
I think the trader that shall not be named may sell of the shelf kits to stroke a 3S as well
crank
If your having the 5S journals custom ground, consider instructing the machine shop to do an off set grind rather than just a standard reduction to journals on the big end, that way you can increase the stroke even further, and this in turn can give you huge scope for compression adjustment, via the lathe on the crowns, you will possibly need to reduce the piston skirts slightly for clearance for the new rotational angle of the rods, you may as well also do a proper job and adjust the weights of the pistons, and balance the engine, (always put the heavy two to the inside pots, and do a full crank balance/nitride job etc, fit lead-bronze bearings, use a decent make like "Vandervell" don't use reticular tin they are poo, should end up with pretty bomb proof bottom end.
Re: Rebuild options
Jun
http://www.junauto.co.jp/products/crank ... ex.en.html
