Rev 3 gts project.
Re: Rev 3 gts project.
what boost is that at?
J-1 wrote:What is the current tune - 431hp?
Is was dyno'd at 431hp at 1.7bar. But when road checking it afterward when aggressively shifting it was detting so lost some ignition. I've also sincere turned the boost down a touch to try to stop gaskets on the exhaust side falling to pieces. It needs some more dyno time ideally but it's just time and money ATM.
Will be interesting to see what it makes next time round.
My track car will be similar I think...
Fully forged 5SGTE
Brian Crower oversize valves, springs, retainers, guides
GSC cams with HKS cam gears
GT3076 turbo with TTE (not WRC!) exhaust manifold
3.5" exhaust system
Huge boot mount IC with SPAL fans
Link G4+ xtreme
Hoping to be mid to high 400's
Fully forged 5SGTE
3.5" exhaust system
Link G4+ xtreme
J-1 wrote:Will be interesting to see what it makes next time round.
Fully forged 5SGTE
3.5" exhaust system
Link G4+ xtreme
Sounds like a beast. Very jealous of the G4+, they released them just after I bought my g4, so I have no inbuilt knock control, had to fork out hundreds more for a knockblock, ridiculous
That's sucks! The G4+ is great value for money so I can't complain. I can't see me outgrowing it spec / capabilities wise.
Hi all. I'm now owner of this beast. Going to remap soon hoping for 500+.
Anyway do someone now why the fans are permanently ON when turning the key?
Did a little acceleration before remap...
https://youtu.be/d-UMsltaWCk
sound like the temp sensor is disconnected. Fans will run all the time without the sensor.
Zemi wrote:Hi all. I'm now owner of this beast. Going to remap soon hoping for 500+.
car sounds/looks an absolute blast.
Is it engine fans? or radiator fans up front? if up front its likely had the AC removed which can cause this issue. if engine fans its what ryan said
Radiator fans do the same. Stick your hand up the drivers side of the rad. You can feel the sensor no bother. Find out if it's connected. A duff sensor will cause the same issue.
Cheers guys. Up the front they are. Engine fans are on the switch.
Could you tell where I can find the sensor please?
There is everything aftermarket on the car. Will try my best. Thanks
Hi all. This car is now for sale. I got it in Europe, but delivering to UK is possible.
The car had some updates like newer turbo (Gen2), 1000cc injectors, mapping (you'll need to remap anyway in UK because of the different barometric weather), Ultra Racing braces under the car etc.
Here I'm including Czech advert. You can either translate or just message me.
£15000
https://www.sportovnivozy.cz/149787-toyota-mr2-500ps
£15000
