mr2 rev2 has a new owner
old bones
Post by old bones »
ok I bought a mr2 rev2 turbo red
former owner must have been called hasie bashi
good points body work is real good no major rust visabile
but
1 nuts missing of turbo
2 dissy cap has 1 screw holding it on,,,,new one here with ht leads
3 rotor arm sreews ar u/s,,,,,,,new rotor arm here
4 tps held on with tiger seal
5 tiger seal used on throttle body
6 ac unit was hanging off, now removed
7 back wheels have different camber
8 has 17"wheels car wonder all over the place
and I drove the car home, has mot,
all above is strip apart from turbo, which is next wash intercool, pipes.
try to find a decent vacuum diagram, what vacuum pipes can be left of.
on the throttle body there is a hot water sensor and a air pipe that goes back to air filter can these be removed
car is a summer car come track car
thanks pete
JD
Re: mr2 rev2 has a new owner
Post by JD »
Hi Pete, sounds like a right mess. Looking forward to some updates about your car as you progress.
Ryan S
Post by Ryan S »
welcome to the club mate, 15 posts and you can post pics, where did you buy the car from??
old bones
Post by old bones »
the dreaded gumtree.lol
Friday bought new stainless bolts washers etc for dizzy cap rotor arm tps started to take turbo and cat off, bolts are rounded, has a stainless exhaust after cat about 3 1/2 bore on down pipe but workman ship is bad, as a x mot man its bad,
totally strip throttle body, can not belive the amount of tiger seal was on faces of body.
its has c26 turbo but off what I don't no its a sh replacement its been marked, brakes are real good vented grove drill discs all round,
body work real solid never been welded which is to be seen to belived as I have failed a few for tin worm before now, one of reasons I bought it body work good,
strip charcoll canister out a few other bits still getting my head round all vacuum pipes struggling to find a good detail diagram for a 1992 m2 turbo import,
once turbo fitted proper and can been gutted, may well strip the inlet get rid of tvis thingy, then I see what can be done with cam timing, with the standard pulleys.
going to get rid of 17" wheels so exchange or anybody want them, I want 16 on it,
done nothing to day so may do a bit on sunday
dazmaz
Post by dazmaz »
Am sure my pal went to see that car! he bought another one in the end be good to see it when its sorted! oh and i am also from Edinburgh :D
Gullzter
Post by Gullzter »
Sounds like a right mess, a bit of hard work and im sure it will look glorious!
A set of staggered 16"s will be perfect :thumleft:
Pics please? :mrgreen:
