Does anyone know what might be causing this judder? I've driven the car a couple of times since and it seems to be fine, it only seems to manifest itself after a long stint on the motorway.
Thanks in advance.
Peter Gidden - SBITS wrote:I trust you had your flywheel surface ground when fitting the clutch?
Engine mount/s loose?
