I have a track day booked for Tuesday but unfortunately I am having problems with the cooling system.
mr2mk2 wrote:Hi all,
I have a track day booked for Tuesday but unfortunately I am having problems with the cooling system.We have tried bleeding it quite a few time over the past month or so because I can hear air in the heater core.
Also, I keep having to top up the coolant even though there are no obvious signs of leaks.
The hfh were replaced recently to cure a leak from them.
It will drive a hundred miles or more with no problems but then could take it out and within a few miles the temp will rise towards the red.
Let it cool down, top up and bleed and then everything OK again for a while.
The radiator doesn't have the little pipe at the side of the bleed screw to attach the bleed pipe so I'm not 100% sure all the air is being bled out.
I am now thinking that the cooling system is pressurising due to a leak in the head gasket as coolant is filling the overflow to the top and sending it out of the overflow pipe.
Rad cap has been changed for a known good one.
Does anybody have any ideas?
