Need to bring my wheel a bit closer to me as I find its a bit outa reach.
but I cant decide between a d1 spec snap off kit ?
Or a b&g solid spacer.
Has any one ever tried the d1 spec and if so what was the quality like?
d1 spec snap off or solid spacer?
Re: d1 spec snap off or solid spacer?
The genuine ones are good quality. The cheap replicas have plenty of play. I've had one fitted, but removed it as it moved the wheel to far away from the stalks for me personally.
dan mkii wrote:Need to bring my wheel a bit closer to me as I find its a bit outa reach.
Or a b&g solid spacer?
Change column for telescopic type?
Didnt give that a thought to be honest peter.
The delimiter is working perfectly also now
