Basically my Turbo which is stuck in my garage got cannibalised for spares for my TRD rep, its too far gone for me to be bothered to put back together. The engine is good with an indicated 91k on the clock, obviously a mixture of miles and kms. The water pipes front to rear leak and I've removed some bits from the engine (just the diverter valve and AFM). Is it worth me putting these bits back so a buyer can see it running? Should I just drop it out as it stands (more risk to buyer, less effort for me).
Or should I just get the scrap man to take the lot. Its got no struts or hubs at the moment and the rear sub frame is half off so I'd have to drag it on casters and get it craned away.
Whats a good rev2 turbo lump worth
Re: Whats a good rev2 turbo lump worth
Is the sump the same as the rev3 if so.. would you consider taking it off and posting it to me before you scrap it lol
