The HKS belt is kevlar coated, so it is stronger.
.but with the same service intervals.
Unless you have increased your rev limit, or are running high lift cam shafts.
it would probably be a waste of money
Plus.
.from memory when Bob Hatton had a pair of the HKS pulleys tested they were significantly out of balance, and needed a lot of correction.
On that basis if you
are![](./images/smilies/spacer.gif)
looking for after market pulleys I would probably avoid them.
