side strip removal
side strip removal
Are they held on with those easily broken plastic snap pins or is there some crazy Japanese glue helping them to stick like shizen to a blanket?
Re: side strip removal
Remove inner trim by seatbelt and your find a couple of bolts to undo.be careful as they snap easily.![](./images/smilies/spacer.gif)
Its the smaller ones where the rear vents are I need off, cheers though mate
If you mean the ones above the side vents it's as said in the second post.![](./images/smilies/spacer.gif)
You will need a deep 10mm socket as their is a long stud on the trim.
Theirs also a cross blade screw in the wheel arch,
Along with another
10mm nut which will most likely sheer
Cheers.
Yet another simple job that's going to p1$$ me off then!
You might be lucky.
I took all of my side strips off the other day and not a single stud snapped
