Hi,
I have a new set of Whiteline Drop Links, these are for the front. They are adjustable from 235 to 260mm. they include dust overs to keep the dirt out.
Mk1 front drop link size is 240 so a perfect fit.
Text taken from Demon Tweeks website:
Specifically designed for anti roll bar use these heavy duty spherical bearing drop links feature high misalignment bearings allowing up to 20 degrees of movement. Suitable for motorsport use they are available in a range of sizes to fit most vehicles. The design means that each drop link has approx 25mm of adjustment in the length to obtain the correct fit.
example image (will upload original image if there is any interest
http://www.jscspeed.com/images/products ... f3da42.jpg
RRP at Demon Tweeks is £129.97 plus postage (£108.31 plus VAT £21.66.)
I am looking for £65 posted - they are new and still in the original packaging
[FINALIZED] Whiteline Universal Spherical Bearing Drop Links to fit mk1
Re: [FINALIZED] Whiteline Universal Spherical Bearing Drop Links to fit mk1
Quick sale needed, will take £52.50 posted.
I still have them. I have just sent you a PM
This Sale has been completed. The Buyer was subby
