R/R Graph
Mr Bognor
R/R Graph
Post by Mr Bognor »
What is the below graph ???
I have a Fly wheel one a wheel one a AFR one but not sure on this one ???
jimGTS
Re: R/R Graph
Post by jimGTS »
power and boost
that says to me nice stable boost and 0.9-0.95bar
Mr Bognor
Re: R/R Graph
Post by Mr Bognor »
This is what i thought but is the power not a bit hi at under 1.0 bar of boost .
Alan
jimGTS wrote:power and boost
jimGTS
Re: R/R Graph
Post by jimGTS »
its good power for the boost.
how do you mean "a bit high"?
i would be worrying more if it was "a bit low"
oem ecu?
stock ignition timing?
got a pic of the AFR?
perhaps a weak fuel pump is leaning the car out a little, hence the good result.
i assume 240-ish at the wheels power wise??
Mr Bognor
Re: R/R Graph
Post by Mr Bognor »
Just thought it would be a bit lower with only that boost but the car had a stage 2 recon turbo .
Below is the AFR and the wheel BHP was 244.9
jimGTS wrote:its good power for the boost.
oem ecu?
jimGTS
Re: R/R Graph
Post by jimGTS »
those afr's do look leaner than usual, which isnt a bad thing as dont look dangerous.
but i would definitely say this is the reason for the additional power.
oem ecu?
oem ignition timing?
these could also be helping.
i wouldnt be overly concerned, pleased if anything.
though i would be watching out for your AFRs if you plan on increasing boost further.
Mr Bognor
Re: R/R Graph
Post by Mr Bognor »
Well i was going to install a MBC and up the boost to 1.15 BAR .
Do you think this will cause a problem then and is it worth it ?
Car has the below so i think
Exhaust & decat
HKS air filter
Grade 7 plugs
all new ignition coil dizzy etc
Stage 2 turbo with cut back exhaust blades and 360 thrust bearings
Greedy style intercooler with sprall fan
ECU and ignition i would guess are std
jimGTS wrote:those afr's do look leaner than usual, which isnt a bad thing as dont look dangerous.
oem ecu?
jimGTS
Re: R/R Graph
Post by jimGTS »
"would guess"?
i would say worth checking this out
you may have a blitz or mines ecu (cool)
and/or your base timing could be advanced a degree or 2 (not so cool)
base timing, you just need a timing gun and a paper clip, easy enough to check.
Mr Bognor
Re: R/R Graph
Post by Mr Bognor »
There was no mention of this when i got the car and all of the other mods were listed .
I will check but if it is on the std ECU and Timing will a + of 0.4 bar knock out the AFR too much ?
jimGTS wrote:"would guess"?
jimGTS
Re: R/R Graph
Post by jimGTS »
noone would usually declare advanced ignition timing.
it could even be done by mistake. but too much and you could be prone to det and knock.
its worth checking.
0.4bar yes it would! would be on the brink of oem fuel cut also.
but you mentioned 1.15bar, this is only 0.2bar more (not 0.4bar) than what your running.
it could lean it out more sure (evne 0.2), could it lean out too much though; only an afr gauge or another dyno run would tell you.
Ryan S
Re: R/R Graph
Post by Ryan S »
just pull back the boot carpet, you will see right away if it's an aftermarket ECU :thumleft:
Mr Bognor
Re: R/R Graph
Post by Mr Bognor »
Yes sorry i was going to set it at 1.15 bar so may check the ECu and timing then fit a MBC then set it up to 1.15 bar then have one last go at SRR on the rollers to see if it is ok .
What would be an ok level if it is set at 1.15 bar on the AFR chart
jimGTS wrote:noone would usually declare advanced ignition timing.
its worth checking.
Mr Bognor
Re: R/R Graph
Post by Mr Bognor »
Ok will have a look tonight with some pic .
Alan
sheppy wrote:just pull back the boot carpet, you will see right away if it's an aftermarket ECU :thumleft:
Marf
Re: R/R Graph
Post by Marf »
All looks fine to me :thumleft:
Mr Bognor
Re: R/R Graph
Post by Mr Bognor »
But if i put in a MBC and up to 1.15 this may upset the AFR .
What is a good / ok reading on the AFR as this is the bit im not sure about ?
Alan
Marf wrote:All looks fine to me :thumleft:
Marf
Re: R/R Graph
Post by Marf »
Mr Bognor wrote:But if i put in a MBC and up to 1.15 this may upset the AFR .
No, it won't. The ECU is mapped to run rich all the way up to fuel cut.
You won't run the risk of leaning out. If anything I'd bet you'll see a richer AFR than at your current boost levels.
If this concerns you, it's programmable ECU time
Mr Bognor
Re: R/R Graph
Post by Mr Bognor »
This is what i thought reading bits as i thought 13.0:1 was a rich mix and my car at the me is at 10.4:1 @ 6900 RPM .
Think the best thing is to fit it set the boost then have another Dyno and if its still at around the 10.4:1 then this is all good .
One other note as its not super rich at the mo will upping the boost make it more rich and drop BHP or is not the way it works as it will be getting more air ?
Alan
Marf
Re: R/R Graph
Post by Marf »
It is richer than stoich for sure, but 13:1 is by no means a rich mix. Most turbocharged OEM cars tend to run around the 11:1 mark.
If I was going to have my MR2 mapped, I'd have the AFR mapped to around 11:1 on boost.
jon_st205
Re: R/R Graph
Post by jon_st205 »
Agreed 11 is good, 12:1 gives good power but no margin for safety really. 10.4:1 is a little low so is costing a little bit in outright power, but is also very safe. Most 3SGTE's on standard ECU's run <11:1.
Jon
Mr Bognor
Re: R/R Graph
Post by Mr Bognor »
Ok so it is rather rich at the mo then so more air ( more boost ) will be ok and if anything will lean it out a bit to a better level .
So 10.4:1 is a good rich mix ?
Alan
