Just an update of the last part installed .
Brake Stopper install
Re: Brake Stopper install
Are these worth while ??
I definitely noticed a subtle difference in pedal feel and response when I installed mine.
3VZ-FE V6 TRD Widebody Replica
Draven wrote "TRD dude. TRD... Can see awesomness from anywhere. "
Draven wrote:Are these worth while ??
The Cusco one i installed on mine made a big difference, even with standard brakes.
Might add that to the list then.
They do firm up the pedal feel, not so much on the MR2 but on the Supra there was quite a bit of flex on the firewall which the BMC stopper is designed to minimise.
For those that aren't aware though, they can only be fitted to cars not equipped with ABS.
Slarty wrote:For those that aren't aware though, they can only be fitted to cars not equipped with ABS.
I've not got ABS
I've got PAPTB (Panic and pump the brakes)
+ 1 and fits nice
Draven wrote:Slarty wrote:For those that aren't aware though, they can only be fitted to cars not equipped with ABS.
I've not got ABS
Just for refrance its on a Mr2 GTS Turbo REV 3
Alan
Alan
Draven wrote:
I've not got ABS
Great expression lol
