Possible fault or fluid not circulating round correctly?
Cheers,
David
GHOST wrote:Cheers Harold.Yes, I do have an aftermarket boss and wheel that came with the car when I got her.
I'll look into that, thanks.
Harold wrote:It's the steering wheel position sensor that is the issue, on the oem boss there is a metal ring that passes through the sensor and should activate the ps.Your problem will either be down to an aftermarket wheel
& boss which doesn't have the part to pass through the sensor or a problem with the sensor itself.
Take your wheel and boss off and have a play with the sensor, pass something through it to see if it is functioning.
I have had this problem for some time and have just put up with it, PAS comes on automatically above 10mph anyway.It can be a pain in slow traffic and parallel parking also if you're not too quick about it.
If you do some searching I have a thread with pictures of the sensor and a discussion of the problem.
