Bilstein
Bilstein
Does anyone know if the standard fit Bilstein dampers can be re-valved as per most Bilstein products ?
Re: Bilstein
tottacrolla wrote:Does anyone know if the standard fit Bilstein dampers can be re-valved as per most Bilstein products ?
Not that i know of. And since the top of the casing is welded as opposed to threaded (like UK cars), AFAIK they are sealed units.
Re: Bilstein
Thanks for the info Peter, much appreciated.
Re: Bilstein
You could try contacting Chris Wilson (trader on the Supra forum), he rebuilds/re-valves JZA80 Supra Bilstein dampers which I believe are similar to the MR2 ones.
[email protected]
[email protected]
