SuperRedMR2 wrote:So it basically replaces both ends, how much for bits?
Yep.I supplied a pair this week.
And i've sourced matching rubber boots too.
[thumleft]
dazzz wrote:I'm no expert but
IanClements wrote:Yep.I supplied a pair this week.
[thumleft]
Thanks for that Pete.Just gone to fit them this morning and noticed that one of the spacers is bent so going to need one of those as well.
Have you got any at the moment?
T.F.S. wrote:I can make those but they would be much higher quality, how long are they?
SuperRedMR2 wrote:T.F.S. wrote:I can make those but they would be much higher quality, how long are they?
Make what exactly?
Twosrus quality is fine anyway
T.F.S. wrote:they dont have boots as peter suggests either.
T.F.S. wrote:What type of rose joint is peter supplying for£18 each?
T.F.S. wrote:The ones I make are far lighter and better quality.
SuperRedMR2 wrote:The twosrus quality is just fine, considering this is the first bit of play that I have in 3 years, i'll settle for their quality.
Took the passenger side off first tonight- applied hardly any pressure to the rose joint nut and this happened
