This car was built and was working well at around 360bhp, a wiring error meant the map was altered so i could nurse it to JAE 2012. AFter this the wiring fault was repaired but during mapping the engine denoated destroying 4 pistons.
The car spec is as it was apart from the turbo and ecu have been removed. Full Spec.
I had planned to replace the engine but due to other comitments i dont have time
Engine, Drivetrain and Brakes:
CP Forged Pistons 86.25mm (damaged need replacing)
Eagle Roads
Kingdom Race Bearings
ARP Head Studs
ARP Main Studs
ARP Flywheel Bolts
Fidanza Flywheel
RPS 450 ft/lb Clutch
TRD Thermostat
Mongoose Exhaust
Grooved Discs
Yellow Stuff Pads
Quickshoft
Uprated Brass Bushes
Suspension and Chassis:
Front Strut Brace
Koni Shocks
Ebiach Springs
Polybushed rear end
Interior and Exterior:
17" Rota Grids
Eagle F1 Tyres
Slim Nuts
Car was rebuilt with full toyota parts including all new water pumper,oil pump, new tensiors etc. Lots of service history with the car. LOADS of history including reciepts for most of the above.
Bad Bits
Engine has gone - Will need new pistons and reboring or a replacment engine. plus turbo and engine loom which was spliced. Standard ECU is still on the car
Rust around 4p piece on door
No Mot or Tax
WIndow on passanger side isnt closed fully, dont know why. theres a small 3mm gap.
Engine is as above. head can be placed back if the buyer wants it but it is pitted from the bits of piston hitting it
Items have been removed so please refer to list above
Obviously needs to be towed or trailered
price £800 no offers
PLEASE NOTE I WILL NOT BREAK, please dont ask
[FINALIZED] T-Bar Mr2 Rev 3 Turbo Repair
Re: [FINALIZED] T-Bar Mr2 Rev 3 Turbo Repair
Murderer! GLWTS
where are you located?
Re: T-Bar Mr2 Rev 3 Turbo Repair
JM_16v wrote:Rust around 4p piece on door
How big is a 4p piece?
Do you have any pics of the engine?
If I hadn't just bought my car I would of brought this in a heart beat
GLWTS buddy
Tom B
GLWTS buddy
Tom B
Epping Essex
4p is similar to a 5pence coming however due to future impact of the economy and inflation it only becomes 4pence. . .
Will post more pics of engine, sills and other info later
am going to wash the car and do some work on the gt4 today, if anyone needs more info than the above please PM me
Looks like im going to drop the block, gearbox, remove the wheels and scrap the shell then. Watch this space
How much would you want for it as a rolling shell?
Hi,
i want to buy the whole car. Is it still available?
Regards, Roland
Regards, Roland
still there at my grans will be cleaning it up within the next two weeks and putting on ebay
Hi,
and i am still interested. Please aswer to my PM.
Regards
Regards
Where are you located scratch that got it..
I'll have a look at the cost of getting it towed.
All on responded to.
sorry all I just want to note rad, intercooler and induction are removed
http://s366.photobucket.com/user/JM_16v ... 4%20folder
Where are you and how much of it needs repair/respraying?
bluesmoke wrote:Where are you and how much of it needs repair/respraying?
I think as far as the add says,it will need an engine rebuild it swap and a few bits on the body work sorting out.
Engine would need to be repaired and removed parts replaced.
Refer to pictures of the shell.
Just to clarify car has had the following items removed : Radiator, Intercooler incl. dump valve , turbo, induction kit,
car will be going on ebay shortly
