I have a rev 3 3sgte with a cracked piston ring. What parts would be required to remove the rev 3 block and install a rev2 block. Are things like exhaust/intake manifold, fuel rail interchangeable ?
[Mk2] [Turbo] 3sgte rev 2 block & rev 3 head
Re: [Mk2] [Turbo] 3sgte rev 2 block & rev 3 head
Assuming that you are keeping the rev 3 head and just replacing the block with rev 2:
anything that bolts to the head (manifolds, fuel rail, water outlet that feeds turbo, engine hangers etc) will be rev 3.
anything that bolts onto the block will need to be rev 2 (water outlet from water pump, water pump, oil pump, sump).
You'll need a rev 2 cambelt but rev 3 cambelt tensioner (as this bolts to the head)
Stick with rev 3 head gasket
I think the water hoses that go around the block under the exhaust manifold will need to be from a rev 2.
Can't think of anything else off top of head.
January 2014
May 2015
Still in the garage...
..the only thing I can promise for sure is slow progress.
May 2015
just have this niggling thought that if I rip out the wiring, then the car will never get out of the garage again.
what he said:
