[Mk2] [NA] Water noise behind dash
my friend has a 92 n/a and i have noticed that when you rev out of gear there is a rushing of water behind the dash but no leaks what would cause this ???
Re: [Mk2] [NA] Water noise behind dash
You have a small air lock in the heater channels - a simple bleed will sort this. The bleed valve is in the frunk. Get some 8mm plastic hose from B&Q and read these instructions:
http://www.mrtwo.net/mr2modproject/mr2modproject.htm
(service - howtos dropdown)
You'll only need the last few bits but you'll learn something.
Remember to set the heater control to HOT.
