So far I've done the following:
Any help is greatly appreciated.
Chr15py wrote:Sounds like you've mentioned your problem- air flow meter on its way out.
If you have a friend near with the same car, try to swap out the AFM and see if it makes a difference.
Chris
mrdb wrote:To check for crank walk( thrust bearing issues
Look at the crank pully and get someone to press clutch in.It will move out
/ in when clutch is pressed if thrust bearings are gone.
If it does move stop driving it untill you can fix it or it will scrap the block/ crank.
If thats ok its probably to do with the AFM as loading changes on the engine when clutch is pressed in.
1991mr2turbo wrote:Hey there guys, I have a 1991 mr2 turbo USDM.The car has a very weird problem that no one can figure out and I've taken it too ALOT of mechanics but still no real solution.
Basically what happens is when the cars cold and I press the clutch, the rpms decrease by 200 but when cars fully warmed up the car stalls out with clutch pressed.
The car seems to drive fine other then this and this only happens when I press the clutch in neutral.
No weird knocking or ticking noises.
One of my mechanics checked the obd codes, and said I have a code 24
( bad intake air temperature sensor/ AFM), could this be the problem or do I have crankwalk?
-Replaced clutch and flywheel
-cleaned iacv and throttle body
-checked crank pulley for visible movement and there was none, also had a mechanic look at it with a prybar and he said no movement what so ever
-Tried several idle reset procedures
Any help is greatly appreciated..
.I'm about to throw in the towel and sell my beloved car
bobhatton wrote:1991mr2turbo wrote:Hey there guys, I have a 1991 mr2 turbo USDM.The car has a very weird problem that no one can figure out and I've taken it too ALOT of mechanics but still no real solution.
Remove the sump and check the thrust bearings.I think you will find they are damaged and so will be the crank
1991mr2turbo wrote:Bump! Anyone have any other ideas on what it could be? All help so far is much appreciated!
Peter Gidden - SBITS wrote:1991mr2turbo wrote:Bump! Anyone have any other ideas on what it could be? All help so far is much appreciated!
Have you sorted the error code yet?
MartinF wrote:If the thrust washers are not too worn then you should just get away with changing them out, but until you take the oil pan off it will be hard to tell.
You can try measuring the play with a dial gauge as there will be a maximum spec in the repair book somewhere.
