Should do but work is involved.
You need to move the gear shift points from the back for the gearbox to the front.
The ratios are different too.
When you say LSD gearbox, I assume it was from an NA celica? As all the turbos are 4wd and then you have a transfer box in place of where the diff would be.
If it's an NA gearbox then it won't accept MR2 turbo driveshafts AFAIK as they are larger.
If it is an NA box then I guess that makes it an S54
(where MR2 Turbos use an E153).
