Ok, well, tried to jack up the car, had problems, no matter how much I lifted it, the rear wheels wouldnt leave the floor, I tried a combination of a mid mounted trolley jack lifting the sideskirt to a point where I could fit a normal
'winder' jack under the rear mounting point and still, no matter what I did she wouldnt lift.
any ideas?
Ive a feeling im going to have to remove the side skirt to allow me decent clearance to fit the trolley jack under the rear mounting point to lift the rear wheel off the floor enough to get the thing off.
Unless someone can tell me if there is a point under the car, from the rear where I can basically lift the whole of the back end up enough?
However thats not my biggest cause for concern, whilst I was lying in the dirt anyway I thought id have a proper nosey under the car, now whilst the actual main body seems clear enough, the sides
(sills I think) have this:
![Image](http://i.imgur.com/r4WaCI4.jpg)
Now is it as bad as I think it is? Have I caught it before it has done any major structural damage.
I will be looking into repairing this and getting the entire of the under of the car coated.
but come on guys, how bad is it?
