Been rushing to get my new springs fitted with limited time, all done but the 2 bolts are goosed so need replacements.
What are the best options?
I need them by wednesday
Camber bolts (yes another problem)
FORGED BUILD (424hp @ hubs): http://www.imoc.co.uk/forums/viewtopic.php?t=170916
Re: Camber bolts (yes another problem)
Rephrase: what options do i have other than toyota that are not much more expensive than them?
Just off phone to toyota, £38 for 2 bolts, 2 nuts and 4 washers
Anyone know if these eibach ones will do and if i buy one set just swap 1 bolt from opposite side of axle?
Ebay item number: 230610100593
That set you have listed is a pair so will do both sides. There are differing opinions on where to fit them but I beleiv its the top with a standard bolt in the bottom.
Eibach ones will do fine but you'll have to be careful which way you put them in as one way increases camber the other reduces it
Thanks red
If you buy a set, you'll get a pair. Use them as just for the top bolts. Demon Tweeks sell them on eBay and normally come next day
Ok cheers, ill just order 2 sets and do the front aswell, geomatry specialist baffled me though.. Said that they usually only adjust the front ones but not the rears, by the end of the call i still couldnt understand what he was on about or what the difference is as i couldnt find any...
Anyone on here know why the rears would be a problem?
He mentioned something about the brake line but the only problem i could see was the brake lind at bottom bolt which i will be keeping standard anyway plus ive put the bolt in from the opposite side of the brake line!
I have a full set of camber bolts here, bought from Sbits, high quality American items but I cant remember the name?
dazzz wrote:I'm no expert but
T.F.S. wrote:I have a full set of camber bolts here, bought from Sbits, high quality American items but I cant remember the name?
Any details? Pics, brand, price please? Thanks
SPC
http://www.spcalignment.com/spc-performance
High quality American items not Chinese made like Eibach.
I am stripping the suspension down at the moment, can send via first class in the morning if you need them, £43 for the full set inc delivery.
Thanks but im just going to get eibachs dude
