ashley wrote:Alright buddy
All good thanks
[thumleft]
Depends what you mean by upgrading, what are you trying to achieve? More power? Stock power but more reliability?
First things first, you need to work out what's gone wrong with your engine and what
(if any) other damage has occurred- not really much point in speculating until you know the deal.
If you've done your ringlands you'd need new pistons- no point in sticking second hand stock pistons in, and for the price of new ones it makes more sense to buy forged.
Stock rods are already forged, so if you're not going mad power wise you should reuse them.
If the bores are damaged you'll need to re-bore to see if the block is re-useable.
Best case scenario is you've not damaged the bores, so you can just get it honed and whack the engine back together with fresh pistons and rings, run it in and then go.
If the bores are damaged you may need to rebore the block, but take as little out as possible to avoid weakening the cylinder walls- you need to know this first cos if you re-bore you'll need oversize pistons to fit it.
Other than that I'd be replacing the main bearings, the big end bearings and thrust washers
(having measured and checked the crank journals for ovality, you could get the rotational assembly
(crank) balanced with the flywheel, rods, pistons and clutch cover as well).
Change all the seals
(use Toyota), and replace all the gaskets.
Inspect the oil pump, if it's in spec I would re-use it.
New water pump, thermostat, cambelt and idlers.
Rebuild the head- so strip it down, clean it out, reseat the valves if they need doing.
Rebuild the head and correct all the shim clearances.
Hope that helps- just shout if you have any more questions mate, I'll do me best
[thumleft]
Ashley
