smoking
smoking
Got an issue with rev 3 turbo engine. Its pudfing black smoke under boost. No fault codes and no loss of oil or water any ideas?
Mr2 Rev1 tubby
http://www.imoc.co.uk/forums/garage.php ... e&CID=4217
my build thread
my build thread
Re: smoking
My Rev2 did this when I picked it up, massive over fueling as my BOV was letting air out and there was some sort of piggy back ECU installed.
Obviously a rev 3 should not over fuel due to an air leak but there may be other reasons it could be doing it.
Re: smoking
when i had a cat fitted i had no smoke, then i removed it and it when you boost hard or stand still and rev it right up it puffs a big black puff.
I wonder if there is an ecu overfueling issue
Mr2 Rev1 tubby
my build thread
my build thread
Re: smoking
Black smoke would generally point to overfueling. If it's recently been decatted perhaps it's a buildup of soot over the years now being cleared out bit by bit when on hard boost.
Re: smoking
nah did it about a month ago
Mr2 Rev1 tubby
my build thread
my build thread
Re: smoking
4ndee wrote:I wonder if there is an ecu overfueling issue
ECU won't overfuel by itself.
Re: smoking
agreed i replaced the lambda sensor and no difference, does the coolant temp sensor adjust fueling on a rev3 like a rev1-2
Mr2 Rev1 tubby
my build thread
my build thread
Re: smoking
4ndee wrote:agreed i replaced the lambda sensor and no difference, does the coolant temp sensor adjust fueling on a rev3 like a rev1-2
All coolant sensors affect fuelling since the engine needs to know when to fuel enrich for cold starting.
Definitely worth checking.
