TO CUT A FLAP... OR NOT CUT A FLAP ??
Hi guys, been working on a friends car for ages now, its an SC conversion with uprated fuel pump, one of the first jobs was to drop in the fuel pump. went to fire her up for the 1st time today, but the pump is dead although we tested it before fitting, we have a feed to the plug where it comes out of the tunnel, but there is no resistance from the pump end of the socket. Now the question is.. do we drop the tank again ( not a nice job at all & anyone who's ever done it will know where im coming from ! ) or do we cut a flap in the tunnel & get to the wiring from there, we are assuming the wire has come off the pump when we put the tank back in. Does anyone have a measurement from the centre of the sender unit to the centre of the fuel pump housing to hand so we know where to cut please, anyone done this that has picture would be a god send too, cheers, Jinxy
Re: TO CUT A FLAP... OR NOT CUT A FLAP ??
I can't help with the measurements Jinxy, but I would go the cutting route if you are careful enough. IME aftermarket pumps just don't last like factory Toyota items so, even if you fix it this time, it might well need doing again in the lifetime of the car. IIRC you can drop the tank a couple of inches to make the cut a bit safer.
Good luck with the project.
Cheers,
Jon
Cheers,
Jon
Cheers Jon much appreciated, yeah we had hoped to drop the tank a few inches anyway before cutting, those pipes on the back of the tank are a real pain in the A***, the pump is a high quality pump so should last a fair while, will let you know how we got on, just need measurements now, cheers, Jinx
Personally jinx I got the dropping route
I think it's safer and less damaging just case something goes wrong and end up wished you just spent a little time doin it properly
Drop the tank mate, there is no way i'd grind open the tunnel and that's coming from someone that will cut anything!
Don't end up consumed by ball of flame please Jinxy
If you can lift the nose of the car high enough you may be able to drop the front of the tank enough to get at the pump without disconnecting all the pipework
