But the outlet pipe to the engine inlet is too hot to touch after a run out.
Wondered if this is normal.
dazzz wrote:I'm no expert but
jimGTS wrote:after a run out, what exactly do you mean by this??
its hot soon as you pull up?
its hot when you feel the pipe 10-20mins after a run?
any static driving, will heatsoak the bay, no matter what setup your using.
any metal pipe in the bay is going to be hot once up to temp.doesnt mean thats how hot the inlet temps will be.
Tedtiler wrote:Intercooler sprayers are available.Easy enough to mock one up or get one off a Subaru impreza that ran one as standard on some models.
jimGTS wrote:Tedtiler wrote:Intercooler sprayers are available.Easy enough to mock one up or get one off a Subaru impreza that ran one as standard on some models.
wonder if you could set something like this to only recome active at a certain boost pressure?
toxo wrote:jimGTS wrote:Tedtiler wrote:Intercooler sprayers are available.Easy enough to mock one up or get one off a Subaru impreza that ran one as standard on some models.
Easily, MAP sensor and a comparator circuit, job done!
Like this except using a MAP sensor not THW:
http://www.mrcontrols.com/installs/temp ... mpctrl.htm
I suspect you can probably buy off-the-shelf'boost switches' or something similar these days though.
Tedtiler wrote:Hi chaps.Havent ran one of these ebay side mount intercoolers before.
Bit worried about the heat its passing on.
The cooler itself is set up on the shroud and sits nicely.
But the outlet pipe to the engine inlet is too hot to touch after a run out.As that is the cool side I expected better.
Std ct26 at 0.8 bar.
Wondered if this is normal.![]()
Lot of power being lost by such a high inlet temp.
bobhatton wrote:
How can you buy a cheap intercooler made in China and think it will work better than the stock Toyota one?
bobhatton wrote:Tedtiler wrote:Hi chaps.Havent ran one of these ebay side mount intercoolers before.
There is your problem"ebay"
Well anythings better than the stock one mate, it's the same size as my old 1.3 starlet one.As far as I know the greddy and arc alternatives are discontinued so all you can do is buy what's available.
Water injection will stop knock but will never cool down your inlet air.
