Having trouble getting new timing belt on, have also replaced water pump.
Does anybody know the number of teeth on a Rev 2 turbo timing belt, water pump, and oil pump?
[Mk2] [Turbo] Number of teeth on Rev 2 turbo timing belt, water pump, and oil pump?
Re: [Mk2] [Turbo] Number of teeth on Rev 2 turbo timing belt, water pump, and oil pump?
Timing belts:
Rev1 & 2= 178 teeth
Rev3+ = 177 teeth
Rev1 & 2= 178 teeth
Rev3+ = 177 teeth
Thanks, my belt is correct then.
But the new water pump has 23 teeth, whereas the old one has 22, so I must have been sent the wrong one.
Its the oil pump that has one tooth less on the Rev 3, as far as I know the water pumps are all the same. It is a Toyota water pump I hope, not one made in China,
Was a cheap ebay one so serves me right! Going to phone TCB this morning to get the right one.
