[Mk2] [Turbo] fuel pressure regulator?
steelyblue
Post by steelyblue »
Had a genuine sard item ordered that was never delivered and cant find any others. ive always used sard for my turbo cars so now im at a loss for what brand to use thats of a similar high standard of quality. can anyone help with this? I know gts chris has aeromotive ones for sale but £150 is a tad steep for an fpr (well priced, jus a bit more than im willing to spend atm. ive a budget of 120 for one so its not like im skimping on price. can anyone help me with this?[/list]
gtschris.com
Re: [Mk2] [Turbo] fuel pressure regulator?
Post by gtschris.com »
steelyblue wrote:Had a genuine sard item ordered that was never delivered and cant find any others. ive always used sard for my turbo cars so now im at a loss for what brand to use thats of a similar high standard of quality. can anyone help with this? I know gts chris has aeromotive ones for sale but £150 is a tad steep for an fpr (well priced, jus a bit more than im willing to spend atm. ive a budget of 120 for one so its not like im skimping on price. can anyone help me with this?[/list]
What is your goal with a FPR? If £150 is too expensive i am guessing your not on stand alone EMS.
www.gtschris.com
tel: 01670 737080
mob: 07786070103
steelyblue
The sard's brand new are 90 delivered. Hence the 150 being top expensive! Its for to stage one my turbo, im not goin for massive power that the aeromotive is made for, im simply going for stage one so it doesnt need to be overly capable. far as i know the aero is capable of dealing with 500bhp?
Nic
Post by Nic »
steelyblue wrote:The sard's brand new are 90 delivered.
I'd question whether that is a genuine SARD FPR, they are between £94-£100 before tax in Japan.
http://www.sard.co.jp/after_eng/product ... lator.html
There are fakes out there: http://www.tunersgroup.com/TunerWire_Li ... _sard.html
Nic
[email protected]
MR2 Rev 3 GT Turbo
gtschris.com
FPR
steelyblue wrote:The sard's brand new are 90 delivered. Hence the 150 being top expensive! Its for to stage one my turbo, im not goin for massive power that the aeromotive is made for, im simply going for stage one so it doesnt need to be overly capable. far as i know the aero is capable of dealing with 500bhp?
If your not on a stand alone EMS and trying to squeeze extra performance out of your 540cc side feeds - there is little or no merit installing an adjustable FPR.
My advice would be to save that £90 and put towards other mods.....
www.gtschris.com
tel: 01670 737080
mob: 07786070103
steelyblue
So a mister is the only turbo that for stage one an fpr isnt required? Please explain im clearly a noob here, any other jap turbo ive had required an fpr for correct set up at stage one #-o
KarlBristol
Post by KarlBristol »
There's loads of genuine ones for sale even on eBay...
http://www.ebay.co.uk/sch/i.html?_trksi ... &_from=R40
They aren't at the £150 that you were worried about either :thumleft:
I also wouldn't be surprised if places like GTS Chris could get their hands on one for you if you call them up. They can normally source anything that I need :thumleft:
steelyblue
See i know chris knows his stuff alot better than most, would pretty much go with whatever he says as he'll know better than i do. always used an fpr though!
jimGTS
Post by jimGTS »
I'm sure the mr2 turbo is not the only Japanese turbo car that uses a rising rate fuel pressure reg as standard.
The reason there not needed is because fuel pressure increases per psi of boost as standard. So whether your running 10 or 20psi, it will either put in +10 or +20psi extra fuel pressure.
As said I'm sure the mr2 is not the only car that uses an oem fpr like this.
Only reason you'd need one is to either raise or lower your fuel pressure to bring it back to stock, or raise if you need to squeeze more pressure/fuel out (assuming you have a way to control the fueling via a EMS/mappable ecu).
ashley
Post by ashley »
What are you defining as Stage 1? What exactly are you planning to do??
