Looking to get a nice oil catch can, want to know what you have (pics) and how its going for you?
Any to avoid?
Oil catch can, what have you got?
- IMOC Committee
Re: Oil catch can, what have you got?
The stock rev3+ turbo one is pretty good, it drains the 'caught' blow-by back into the sump and everything!
Im cleaning up engine bay aswell so looking to do away with a few pipes and going for polished parts so just want to know what others are using, anyone using fleebay catch cans?
Why replace the perfectly good oem catchcan with some dodgy chinese tat?
I remember reading the ebay ones dont have any baffling inside them so they dont separate the oil from the air. Also i've heard that the crap hoses that come with those things also cause issues.
- IMOC Committee
That article is mainly based around 4mm internal, the internal of ones im looking at are 15mm
There must be a few people on here running them?
I used to have a Cusco catch can on my rev 2 engine. Got a rev 3 now so using the stock one.
Bet those are not true 15mm ID thou, but do infact have fittings of 15mm external diameter!
Those eBay fittings are upwards of 2-3mm thick!
So your looking at ID of 9mm, not 15mm, even thou the hose maybe 15mm ID the fitting may go down to 9mm.
One thing I would note thou to people!
Has anyone seen the ID of the oem hole in the standard rev3+ turbo hose?? Ie taken out the metal joiner and looked, and this goes down to probably 7 or so mm! I'll be drilling this out very soon. This is on an oem setup.
Ok ill find out what the ID is of some on ebay, tbh i wouldnt use much ebay stuff something like this surely cant go wrong?
Anyone noticed a difference between the ones with small filter at top compared to ones that dont?
The ID of the one im looking at on ebay is 11.7mm bore
Bit of a daft question. Are these only for tubby's?
Ryan6926 wrote:Bit of a daft question. Are these only for tubby's?
No
